Activity Forums Apple Final Cut Pro Legacy Connecting DVC PRO HD camera via Firewire
  • Matt Larson
    January 25, 2007 at 11:18 pm
    The camera should be set to go unless you changed a setting deep in the menus.
    In FCP, you should use the DVCProHD Easy setup that matches your footage frame rate. So, if you are shooting 720p60, choose DVCProHD 720p60.
    But, you will need to change “deck control” to “Non-controlable” in the capture window. The camera does not support control over Firewire.
