Activity › Forums › Blackmagic Design › Connecting a Beta SP Machine Via a DigiBeta deck
Posted by Edward J destructo on August 16, 2006 at 3:20 amI know this is supossed to be possible but can anyone please explain the best way to accomplish this? I need to get some Beta Sp material into my HD Pro dual link.
Cheers
Edward J destructo replied 20 years ago 4 Members · 6 Replies -
Bryan Keith
August 16, 2006 at 3:25 pmYou simply run the component outputs from your beta to the component inputs of your digibeta. Also run the xlr audio out from the beta into the digi. Make sure that on the digi deck you swith the video input switch from SIF to component. I do this all the time with my setup. Works like a charm.
Edward J destructo
August 21, 2006 at 3:24 amwhat is the best way to get audio in from the digibeta deck using the HD PRO dual link card? pictures are all good via SDI but we are unable to get audio in????
the deck is a DVW-500p digibeta
Kristian Lam
August 21, 2006 at 4:01 amHi
We support SDI embedded audio. Make sure the audio output is set to SIF and you will be able to capture both video and audio together.
regards
Kristian Lam
Blackmagic Design -
Edward J destructo
August 21, 2006 at 4:31 amThank you for such a quick response!
Am I correct in assuming that the ‘DeckLink Audio Device’ overrides a PC’s onboard audio output?
I am using an Intel D975XBX motherboard and can’t seem to get any sound out via the motherboards speaker jack.
Cheers
