Connect TV to Computer
Posted by Vegasarian on April 15, 2006 at 4:20 pmCan anyone run this thicko thro the process of connecting a TV to computer in order to look after my vegas colour balance. I have connected to S video output of nvidia Geforce graphics card and into scart socket of Sony TV. On computer start up I get occasional glimpses of computer on the TV screen in black and white. (Wondering if this might be an NTSC/PAL problem as I write this). Sony TV is PAL. I notice also that the picture on the TV has become skewed since connecting to computer, both in AV and TV mode.
Edward Troxel replied 20 years, 4 months ago 4 Members · 9 Replies -
Alexander Gao
April 15, 2006 at 4:42 pmYou could go video out from firewire, through a deck/camcorder, and use the deck/cam’s video out to go to the tv. Just make sure you have your settings and preferences correct to output video from firewire.
Alexander Gao
“When the revolution happens, I’ll be leading it.”
Edward Troxel
April 15, 2006 at 8:21 pm -
Vegasarian
April 15, 2006 at 8:28 pmWell! that was spooky! mr. Troxel…seconds apart!!!! so…how to treat as a secondary monitor so vegas will allow?
Edward Troxel
April 15, 2006 at 8:48 pm -
Vegasarian
April 16, 2006 at 4:48 amOK…You’re gonna tell from this I’m a cameraman and not an Engineer. I have a little ENG Monitor SONY PVM something or other (PAL) with BNC input. Is it going to be easier for me to use that for my video quality control. Can I get from S-Video or Firewire from computer with less trouble than trying to use Sony Trinitron TV?.
Allen Zagel
April 17, 2006 at 9:55 amMy TV Monitor is connected to a Canopus ADVC-100 analog/digital converter, then via firewire to the computer. No problems. Works fine. However my set-up is NTSC.
If I need to capture analog from a VHS tape, then I connect a VHS machine to the front of the ADVC-100.
Simple procedure.
AllenMy web site features;
China, China Railways and music.
https://www.azagel.comVideo site;
https://www.asxvideo.com
NEW! Shanghai MagLev DVD. -
Vegasarian
April 18, 2006 at 12:06 amYep >>
Problem seems to be…Im using a Sony camcorder and firewire socket is marked ‘DV-OUT’ not ‘DV-IN/OUT’
So it seems not all Sony Cameras accept firewire IN.
Edward Troxel
April 18, 2006 at 1:21 am
