Activity › Forums › Adobe Premiere Pro › connect Premiere Pro Cs4 program feed to LCD
Posted by Chris Saflar on July 22, 2010 at 9:50 pmHow can I see the HD program output from Premiere Pro CS4 to an LCD tv. Can I use the HDMI out on the video card or use the Blackmagic extreme HD card for the output. How do I set this up? Thanks!
Vince Becquiot replied 16 years, 1 month ago 2 Members · 12 Replies -
Vince Becquiot
July 22, 2010 at 11:10 pmHi Chris,
As long as your card has a dual head, you can use the second output to DVI or HDMI and display a full screen output to a monitor or television. Or you can add a second card.
Once the monitor is plugged in, go to your playback settings and set the second display as external monitor. You may have to go to your Windows / Mac display settings and set the second display as extended first.
You can also use a Blackmagic card but you will need to setup Blackmagic projects in order to use it.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Vince Becquiot
July 23, 2010 at 7:17 pmLook on the right top side of your program / preview panel. That’s inside the small contextual menu.
Vince Becquiot
Kaptis Studios
Chris Saflar
July 26, 2010 at 8:56 pmHey, the realtime playback makes the video jitter on the computer and the external monitor. How can I fix this problem?
chris
Vince Becquiot
July 26, 2010 at 9:19 pmHi Chris,
Are you by any chance using an ATI card?
Vince Becquiot
Kaptis Studios
Chris Saflar
July 27, 2010 at 4:44 pmYes, an ATI Radeon HD 4890 card in the PCI express slot. Why ?
Vince Becquiot
July 27, 2010 at 5:30 pmIt’s a common issue with newer ATI drivers. I’m not sure where the blame lies, but see if that fixes your problem.
Vince Becquiot
Kaptis Studios
Chris Saflar
July 28, 2010 at 8:40 pmnone of the old drivers are working. Should I just switch out the ATI card with a nvida or better ATI card? What do you think?
chris
Vince Becquiot
July 28, 2010 at 8:44 pmI’d say, get something you can possibly return if that doesn’t solve your issue, but I have a feeling ATI is at the root in that case.
It certainly could be a host of reasons. What kind of machine are we talking about?
Vince Becquiot
Kaptis Studios
