Activity Forums AJA Video Systems Connect Kona 3 to HDW 1800 – 720 24p to 1080 60i
  • Connect Kona 3 to HDW 1800 – 720 24p to 1080 60i
    Posted by David J. stewart on August 22, 2008 at 11:13 pm
    Any consultants out there to walk me through this?
    I am printing a one hour doc to HDCam for the broadcaster 1080 60i.
    The film was shot DVCPro720 24pn and the locked picture is in an Apple ProRes 422 sequence.
    How do I connect the HDW1800 deck, Panasonic 26″ monitor and set finalcut/Kona 3 to output 1080 60i ?
    I will also have to stripe the tape first and do an edit to tape?
    David Stewart
    Technical Dir. ICS
    Inuvik NT
    867 777-2320
    David J. stewart replied 18 years ago 1 Member · 1 Reply
  • David J. stewart
    August 29, 2008 at 10:10 pm
    Wow I’m shocked at how easy this was to do.
    I am looking at a 720 24p Prores sequence and holding a 1080 60i master in my hand and I didn’t even need a sync generator to pull it off, sweet!
    Thx to Rudy over at AJA for the tips…
    No documentation however one recommendation: Menu 309 on the VTR set it to
    AUTO2.
    720p24 is displayed as 720p59.94.
    To cross-convert on capture:
    1) Go to AJA control panel -> format and set secondary to 720p59.94.
    2) Setup FCP with a AJA Kona 1080i29.97 easy setup.
    To cross-convert on playback:
    1) Setup FCP with a AJA Kona 720p23.98 easy setup.
    2) Set the video playback to AJA Kona 720p59.94.
    3) Go to AJA control panel and set secondary to 1080i29.97.
    4) Go to AJA control panel -> analog or digital out and set to secondary.
    Let me know if you have more questions.
    Thank you
    Rudy
    David Stewart
    Technical Dir. ICS
    Inuvik NT
    867 777-2320
