Activity Forums Adobe After Effects Expressions Connect a 2d icon to a 3d map (distorted with corner pin)
  • Connect a 2d icon to a 3d map (distorted with corner pin)
    Posted by Dominic Tremblay on February 2, 2011 at 7:09 pm
    Hello!
    I have a 2d map that is animated (map_flat precomp). This precomp is then integrated in the main comp as a 3d layer, rotated 30 degrees in X and with a corner pin distortion to increase the perspective. i need to pin a 2d icon to a street corner. I tried using a copy of the map flat precomp in the main comp without the corner pin effect but my icon is sliding.
    I guess i could use a null in the precomp and then use toComp or toWorld but I’m not to sure how they work and how to compensate for the corner pin.
    Any ideas?
    Thank you
    Dominic Tremblay replied 15 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
