Activity Forums Apple Final Cut Pro Legacy Confusion about Master Clip Sub Clip Relations
  • Confusion about Master Clip Sub Clip Relations
    Posted by Aksekili on August 24, 2006 at 3:35 pm
    Okay, so I’ve captured my footage 10 bit uncompressed, but we didn’t have a jammable slate, so I have to sync everything up in post. I thought it wouldn’t be a problem. I laid out the video and proceeded to lay the audio clips under it. As i synced up each take with the audio, I used the razor blade to cut the video to correspond with the audio (so its one big video file cut into smaller pieces with different audio files under each piece). I thought that I would’ve been able to lay markers on the timeline and then swirly arrow down next to the sequence, select all the markers, and make the clips independent. BUUUT, I guess that doesn’t work with sequences. So, how can I make those clips appear in the browser, where i can rename them with shot name and take numbers? I tried apple L linking the audio and video and dragging it into the browser, but when I bring up that clip, its still the half hour video clip with in and out points. I tried deleting the master clip, but the same thing still happened. I also tried copying the sequence into a new project. I’ve been going over and over the subclip and mastr clip relations, but to no avail. Oh yeah, im on mac os x and FCP HD 4.5. Any help would be greatly appreciated,
    Dane
    Aksekili replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
