Activity › Forums › Adobe Premiere Pro › confused which transcode setting to use
  • confused which transcode setting to use
    Posted by Donmciij on May 17, 2005 at 5:06 am
    this has something to do with adobe premiere 1.5. i am confused which transcode setting to use in the “adobe media encoder” since there are vast choices of presets.
    i tried using this format: “mpeg2-dvd”, preset: “NTSC DV 4×3 high quality 7mb CBR 2 pass”. but after transcoding my 1 hour and 20 minutes video, the total file size soared up beyond 4.7gb and it wont fit to a single dvd-r.
    any idea what is the right transcode setting or preset in the premiere’s “adobe media encoder” that would fit to a single 4.7gb dvd disk with good quality and playable to most home dvd players?
    by the way im using adobe encore to author dvd’s but i haven’t tried transcoding there. what i usually do is transcode my work first at premeire then import as asset to encore. i hope i’m doing it right.
    thank you very much, your help will be appreciated.
    blessings,
    donmciij
    Donmciij replied 21 years, 4 months ago 3 Members · 5 Replies
