Activity › Forums › DVD Authoring › confused about ntsc vs pal on DVD all region??
  • confused about ntsc vs pal on DVD all region??
    Posted by Sophie Watson on February 3, 2007 at 11:41 pm
    hello..
    Brought my film into DVD Studio Pro and had settings to Pal/secam (as i live in UK my video is 25fps pal.) Then i authored an all regions DVD.
    If i want to show it to people who say they can play NTSC DVD, do i have to re-author with preferences set to NTSC?
    Or do i actually have to go to After effects and rerender as 29.97fps and maybe even change the aspect ratio? 🙁 🙁 🙁
    It’s a music video so sound synch is quite important. i don’t really understand what will happen to my frame rate and don’t particularly want it to change..
    confused..
    thanks in advance for any clues people may have
    :S
    Julian Alto replied 19 years, 8 months ago 3 Members · 4 Replies
  • Julian Alto
    February 4, 2007 at 3:20 pm
    Hello, well the best way to do this process (PAL >> NTSC) is by hardware.
    Another way is using the compressor 2, but it
  • Arnie Schlissel
    February 4, 2007 at 4:44 pm
    In order to author an NTSC project in DVDSP, you need to use NTSC assets. It will not import PAL assets into a NTSC project (nor will it import NTSC into PAL). You can convert your assets using Compressor, or you can buy Nattress Standards converter (https://www.nattress.com/) for $100. Or you can take your PAL video to a service bureau to have it done with proper hardware, which will probably look much better.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Sophie Watson
    February 5, 2007 at 12:37 am
    thanks,
    but i’m wondering, if i just send a PAL region 0 DVD to someone using an NTSC DVD player what will they see?
  • Julian Alto
    February 5, 2007 at 2:32 pm
    Nothing
