Activity › Forums › Adobe Premiere Pro › Conforming Sped Up High Frame Rate Clips To Look Like 25fps
  • Conforming Sped Up High Frame Rate Clips To Look Like 25fps
    Posted by Alex H-white on October 21, 2010 at 7:45 pm
    I’m working on a project using R3D clips at three different frame rates: 25, 50 and 120fps. I have had to speed up some of the higher frame rate footage to play in “real-time” in a 25fps sequence, but cut next to the 25fps clips it looks noticeably different; the cinematic blur is gone.
    Is there any way to conform sped up, high frame rate footage to look like 25fps? Ideally working in AP, but i can use AE or FCP if needs be.
    Bob Dix replied 15 years, 11 months ago 2 Members · 1 Reply
  • Bob Dix
    October 22, 2010 at 10:05 pm
    Click on clip/s ie., Right click> window opens>Clip Speed/Duration alter %, check Maintain Pitch > OK
    Freelance Imaging & Video
    AUSTRALIA
