Activity Forums Apple Final Cut Pro Legacy Conforming Red
  • Posted by Michael Cheung on April 21, 2010 at 12:22 am
    There’s a lot of posts around the web on this subject and it’s very difficult to figure out the best / possible ways of conforming a sequence to the original R3D files.
    This is what has happened so far on the feature I was involved with:
  • The film was shot on the Red Cam at 4k 2:1
  • The rushes were transcoded into DV PAL using Red Rushes
  • The film was offline edited in FCP and is now picture locked
  • The film is very low budget and can’t afford too much time in a post house.
    Now we need to get to HD-CAM SR for Edinburgh Film Festival.
    Oh yeh, they also want a 35mm Film Print – just thought I’d drop that bombshell in!
    So my question is one about conforming. What is the best way to get to where we want?
    My thoughts so far:
  • Using Clip finder and importing the sequence XML
  • Replace the clips in the sequence xml (using clipfinder) to be that of the 2k Red Proxy (as I understand I couldn’t do it to the 4k R3D files?
  • Import XML back into FCP
  • Send sequence to Color and Grade
  • Render to DPX or ProRes
  • Send to FCP for titles etc.
  • Export as Uncompressed quicktime and hope that a Post House can put that to a HDCAM SR
  • Has anyone experienced this type of workflow from DV PAL? And if the grading needed to be done in a post house what adjustments would be made to the above? What are people’s thoughts on going from the 2k to 35mm and going from a 4k to 35mm – is it worth the extra effort / cost to do 4k over the 2k?
    Thanks to this community for being amazing – thoroughly enjoy reading all contributions!
    Michael Cheung
    Editor/Assistant Editor/DIT
    http://www.filmcutter.co.uk
Michael Sacci replied 16 years, 5 months ago 2 Members · 1 Reply
  • We use anonymous cookies to give you the best experience we can.
