Activity Forums Apple Final Cut Pro Legacy Conform to sequence – keeping keyframes
  • Conform to sequence – keeping keyframes
    Posted by Jeff Gerst on June 29, 2010 at 2:59 pm
    I have changed the aspect ratio of a sequence I am working on. I found I needed to use “conform to sequence” to get the media in the right aspect ratio. This causes me to lose all my keyframes – any way to get the media into the proper aspect ratio without losing the keyframes?
    Thx
    Jeremy Garchow replied 16 years, 2 months ago 2 Members · 18 Replies
  • 18 Replies
  • Jeremy Garchow
    June 30, 2010 at 1:38 pm
    What exactly did you do?
  • Jeff Gerst
    June 30, 2010 at 2:02 pm
    I changed the settings on my sequence to improve the resolution of screen captures – see attached. Then I needed to change the media to conform to sequence.
    TO:
  • Jeremy Garchow
    June 30, 2010 at 2:45 pm
    I don’t get it. 720×404? Why not just export from the 960×720 timeline? How does going from a bigger frame size improve your resolution?
  • Jeff Gerst
    June 30, 2010 at 3:34 pm
    We are finishing with 720×404 videos.
    I have screen capture from Camtasia at 1280×720 & the only way it doesn’t look like crap on export is to use the 2nd set of settings. I tried just about everything else I could think of.
  • Jeremy Garchow
    June 30, 2010 at 3:35 pm
    [Jeff Gerst] “We are finishing with 720×404 videos.”
    But that doesn’t mean you should edit 720×404.
    [Jeff Gerst] “I have screen capture from Camtasia at 1280×720 & the only way it doesn’t look like crap on export is to use the 2nd set of settings”
    How are you exporting?
  • Jeff Gerst
    June 30, 2010 at 3:40 pm
    Exporting using all current settings. The problem is when you encode a 1280×720 or 960×720 export at 720×404 (our video player size), the camtasia screen capture looks awful. When I cut in a sequence that is 720×404, what you see is what you get in resolution. Even when the screens look clean in a 1280×720 export, on encode they get fuzzy.
    So the solution that I found was changing to 720×404 & Animation codec to keep the screen captured text clean.
    If you have any thoughts on things to try, I’d appreciate it!
  • Jeremy Garchow
    June 30, 2010 at 3:42 pm
    [Jeff Gerst] “If you have any thoughts on things to try, I’d appreciate it!”
    Export your movie as File > Export > Quicktime Movie at current settings leaving recompress all frames and make self contained UNchecked.
    Bring that movie in to Compressor and make whatever codec you need at 720×404 and in the frame controls set the resize to best.
    Jeremy
  • Jeff Gerst
    June 30, 2010 at 3:46 pm
    OK will try that. Part of the problem is that I couldn’t even get the text looking clean at 960×720 – will work on that. Thx.
  • Jeremy Garchow
    June 30, 2010 at 3:48 pm
    [Jeff Gerst] “OK will try that. Part of the problem is that I couldn’t even get the text looking clean at 960×720”
    What format are the camtasia records? I know you said 1280×720, but what codec and frame rate?
    How are you monitoring your footage?
  • Jeff Gerst
    June 30, 2010 at 3:50 pm
    I believe they were in 1280×720 to capture most of the screen – I was going to try to get the camtasia in 96×720 & see if that helped.
