Activity › Forums › Apple Final Cut Pro Legacy › Conform to sequence – keeping keyframes
Jeremy Garchow replied 16 years, 2 months ago 2 Members · 18 Replies
Jeremy Garchow
June 30, 2010 at 3:57 pm[Jeff Gerst] “I believe they were in 1280×720 to capture most of the screen – I was going to try to get the camtasia in 96×720 & see if that helped.”
Don’t do that. 1280×720 is fine.
What codec? How are you monitoring your footage?
Jeremy Garchow
June 30, 2010 at 4:16 pm[Jeff Gerst] “main one was techsmith’s codec.”
And you just brought this in to FCp without transcoding first?
Jeremy Garchow
June 30, 2010 at 4:16 pm[Jeff Gerst] “Not sure what you mean by how am I monitoring the footage?”
On what monitor are you watching the footage?
Jeff Gerst
June 30, 2010 at 4:35 pmWatching the footage on both the Mac I’m cutting on & the PC.
Again, the biggest issue is after final encode that it looks terrible. I will try your suggestion, though.
Jeff Gerst
June 30, 2010 at 4:51 pmI did it both ways – any recommendation on how to export & transcode form Camtasia? I was using the QT mov export.
Jeremy Garchow
June 30, 2010 at 4:52 pm[Jeff Gerst] “I was using the QT mov export.”
To the techsmith codec? Try something better like Animation or PhotoJPEG. You can then take that to COmpressor to transcode to ProRes or DVCPro HD.
Jeremy
