Activity Forums DaVinci Resolve Conform page – No image of the timeline on the recorder side.
  • Conform page – No image of the timeline on the recorder side.
    Posted by Ronen Pestes on January 10, 2013 at 8:35 pm
    I am having this issue when I don’t see any image of the time line on the Conform page – recorder side.
    See attached image.
    I have tested few projects and timelines, also enabling disabling video tracks with no change.
    Is it something that I just didn’t enable the right check-box in the setting page?
    The Color page works fine.
    MacPro 3.1
    Resolve 9.0.4 with Desktop Video 9.6.9
    Ronen
    Jake Blackstone replied 13 years, 7 months ago 3 Members · 3 Replies
  • Peter Chamberlain
    January 11, 2013 at 1:54 am
    Um…. if you select play then stop does the image return?
  • Ronen Pestes
    January 11, 2013 at 4:21 pm
    Yes!
    Is that a ‘normal’ behavior? I need to push the play each time I am loading a sequence and offline clip. (both sides will be dark until I hit the play)
    Thank you.
    Ronen
  • Jake Blackstone
    January 12, 2013 at 8:03 am
    Yep, that’s the way it works. You must push play to see it, but not every time:-) Pretty annoying…
