Activity › Forums › Apple Final Cut Pro Legacy › Conform HPX 48fps Footage to Canon 7D 24p
Posted by Bill Brownstein on December 17, 2009 at 9:53 pmI recently shot some footage at 48fps on my Panasonic HPX-170 and I’m trying to match it up to 24p stuff I shot on my 7D. I increased the speed % of the 48fps footage to 200%. It’ll start fine but slowly drift more and more out of sync.
Is there a more exact number to alter the speed by or do I have to do something totally different to sync this stuff up? Thanks!
Jeremy Garchow replied 16 years, 8 months ago 3 Members · 14 Replies -
Jeremy Garchow
December 17, 2009 at 10:36 pmRight click on the file in the Finder and choose Open With > Cinema Tools.
Then hit the conform button and choose 23.976 (or 24.0 depending on your 7D footage).
Jeremy
Bill Brownstein
December 17, 2009 at 10:55 pmSince I shot the Panasonic footage in 48fps (slow motion) it already appears in the timeline as 23.98. So it doesn’t seem to be the frame rate that’s the problem but the velocity at which the clip is played back.
I’m able to successfully sync the 7D footage to an audio track that was recorded separately at the shoot. No matter what percentage I speed the Panasonic footage to I can’t get it to conform to either that separate audio track nor the 7D footage.
Jeremy Garchow
December 17, 2009 at 10:59 pmBut you shot the Panasonic footage at half the speed, so no wonder it doesn’t sync?
Bill Brownstein
December 17, 2009 at 11:56 pmRight, but by changing the speed at which the footage plays back, I should be able to make it play as if I shot it at the normal frame rate. That’s why I don’t understand why it doesn’t sync up when I speed it up 200%.
Either it needs to be a more exact number (like 201.10% for example) or there’s something major I’m missing.
Bill Brownstein
December 18, 2009 at 12:07 amIf with the Panasonic I shoot for one minute at 48fps, the resulting clip when I bring it into FCP is 2 minutes long at 23.98. So going by that, I should be able to speed up the velocity to 200% and get a clip that plays just as if it was shot in 24P, right?
Jeremy Garchow
December 18, 2009 at 12:57 amGo by time instead of percentage take the amount of time and divide it by two instead of entering 200%.
Bill Brownstein
December 18, 2009 at 1:05 amHow do I conform the time of the clip?
My test 48fps clip is 03:09:08 so half of that is 01:34:16.
Jeremy Garchow
December 18, 2009 at 1:10 amPut the clip on a new and separate timeline. Select it and hit command-j.
Bill Brownstein
December 18, 2009 at 1:34 amTried it and it still doesn’t work. Nice to know about that option though. Maybe there’s something else wrong that I’m not thinking of. I can’t really understand why this doesn’t work; there must be a way.
Rafael Amador
December 18, 2009 at 10:33 am
