Activity Forums Adobe Photoshop Conform brush stroke to a path?
  • Conform brush stroke to a path?
    Posted by Michael Garske on March 23, 2014 at 4:16 pm
    Is there anyway to restrict a brush stroke to be centered around a path? I’d like to manually use a brush but have the stroke be constrained by the shape of a path.
    Thanks for your help!
    Jeff Hinkle replied 12 years, 6 months ago 2 Members · 1 Reply
  • Jeff Hinkle
    March 24, 2014 at 4:38 pm
    If I’m understanding correctly what you want to do:
    Draw your path.
    Select your Brush tool.
    Set the brush the way you want it (size/shape/color).
    In the Path palette, select the path and click the Stroke Path with Brush button at the bottom (the hollow circle).
    That should stroke your path with the selected brush.
    If you have Illustrator, you can do basically the same thing but with a lot more flexibility, especially if you want to go back and edit the path or brush later.
    It is easier to destroy than to create.
    More fun, too.
