Activity Forums Maxon Cinema 4D Concertina Cloth
  • Concertina Cloth
    Posted by Alex Reardon on May 18, 2011 at 7:55 pm
    I am looking to find a way to show a theatrical drape open and close. In essence and plane concertina’ing with one side locked and the other “collapsing” into it. I’ve tried “Belting” but run into problems moving the indevidual points. Is there a deformer that would achieve this effect simply and quickly? If so; which one, and what settings would you guys recommend?
    Thank you again.
    Alex.
    Adam Trachtenberg replied 15 years, 4 months ago 3 Members · 4 Replies
  • Brian Jones
    May 19, 2011 at 1:44 am
    there are some older threads, do search for “curtain” but it looks easiest to make the curtain folded first then attach that to belt points on top that move apart to open the curtain.
  • Alex Reardon
    May 19, 2011 at 3:51 pm
    Thank you Brian,
    I’ve done that in the past, but I’m hoping to find some way of having a control point that I can affect via espresso to have “Drape Open” / “Drape Closed”. Manually moving all the belt points seems rather twentieth century.. 🙂
  • Brian Jones
    May 19, 2011 at 6:16 pm
    how are you setting it up? Multiple separate points like a real curtain or one long belt on top? Both should be able to be controlled by xpresso
  • Adam Trachtenberg
    May 19, 2011 at 7:11 pm
    You could very easily set up an xpresso slider to control the scale of the belt object in this file: 2368_curtainpull.c4d.zip
