Activity › Forums › Compression Techniques › Concatenated File has Video but no audio?
  • Concatenated File has Video but no audio?
    Posted by Les Garten on August 23, 2015 at 4:28 am
    I am having an issue with this concat command: ffmpeg -i “concat:Part1.ts|Part2.ts” -c copy -bsf:a aac_adtstoasc output.mp4
    I converted 2 mp4 files to ts to concatenate. These files work perfectly when played separately as ts files. When I concat, I get perfect video with no audio.
    Here is the mp4 codec info:
    Stream0
    Type: Video
    Codec:H264-MPEG-4 AVC (part10)(avc1)
    Resolution:3840×2160
    Frame Rate:29.970029
    Decoded Format:4:2:0 YUV
    Stream 1
    Type:Audio
    Codec:MPEG AAC Audio (mp4a)
    Channels: Stereo
    Sample Rate: 48000 Hz
    I’ll attach the file shoring the error
    Any idea what is going wrong?
    ffmpeg started on 2015-08-22 at 00:38:57
    Report written to "ffmpeg-20150822-003857.log"
    Command line:
    ffmpeg -i "concat:Part1.ts|Part2.ts" -c copy -bsf aac_adtstoasc -report full.mp4
    ffmpeg version N-74539-g45f3d4e Copyright (c) 2000-2015 the FFmpeg developers
    built with gcc 4.9.3 (GCC)
    configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
    libavutil 54. 31.100 / 54. 31.100
    libavcodec 56. 58.100 / 56. 58.100
    libavformat 56. 40.101 / 56. 40.101
    libavdevice 56. 4.100 / 56. 4.100
    libavfilter 5. 36.100 / 5. 36.100
    libswscale 3. 1.101 / 3. 1.101
    libswresample 1. 2.101 / 1. 2.101
    libpostproc 53. 3.100 / 53. 3.100
    Splitting the commandline.
    Reading option '-i' ... matched as input file with argument 'concat:Part1.ts|Part2.ts'.
    Reading option '-c' ... matched as option 'c' (codec name) with argument 'copy'.
    Reading option '-bsf' ... matched as option 'bsf' (A comma-separated list of bitstream filters) with argument 'aac_adtstoasc'.
    Reading option '-report' ... matched as option 'report' (generate a report) with argument '1'.
    Reading option 'full.mp4' ... matched as output file.
    Finished splitting the commandline.
    Parsing a group of options: global .
    Applying option report (generate a report) with argument 1.
    Successfully parsed a group of options.
    Parsing a group of options: input file concat:Part1.ts|Part2.ts.
    Opening an input file: concat:Part1.ts|Part2.ts.
    [mpegts @ 0000000002fa1220] Format mpegts probed with size=2048 and score=100
    [mpegts @ 0000000002fa1220] stream=0 stream_type=1b pid=100 prog_reg_desc=
    [mpegts @ 0000000002fa1220] stream=1 stream_type=f pid=101 prog_reg_desc=
    [mpegts @ 0000000002fa1220] Before avformat_find_stream_info() pos: 0 bytes read:32768 seeks:0
    [h264 @ 0000000002fc79a0] non-existing SPS 0 referenced in buffering period
    [h264 @ 0000000002fc79a0] no picture ooo
    [mpegts @ 0000000002fa1220] Probe buffer size limit of 5000000 bytes reached
    [mpegts @ 0000000002fa1220] decoding for stream 0 failed
    [mpegts @ 0000000002fa1220] rfps: 27.500000 0.019811
    [mpegts @ 0000000002fa1220] rfps: 27.583333 0.018497
    [mpegts @ 0000000002fa1220] rfps: 27.666667 0.017228
    [mpegts @ 0000000002fa1220] rfps: 27.750000 0.016004
    [mpegts @ 0000000002fa1220] rfps: 27.833333 0.014825
    [mpegts @ 0000000002fa1220] rfps: 27.916667 0.013691
    [mpegts @ 0000000002fa1220] rfps: 28.000000 0.012603
    [mpegts @ 0000000002fa1220] rfps: 28.083333 0.011559
    [mpegts @ 0000000002fa1220] rfps: 28.166667 0.010560
    [mpegts @ 0000000002fa1220] rfps: 28.250000 0.009607
    [mpegts @ 0000000002fa1220] rfps: 28.333333 0.008699
    [mpegts @ 0000000002fa1220] rfps: 28.416667 0.007835
    [mpegts @ 0000000002fa1220] rfps: 28.500000 0.007017
    [mpegts @ 0000000002fa1220] rfps: 28.583333 0.006244
    [mpegts @ 0000000002fa1220] rfps: 28.666667 0.005516
    [mpegts @ 0000000002fa1220] rfps: 28.750000 0.004833
    [mpegts @ 0000000002fa1220] rfps: 28.833333 0.004196
    [mpegts @ 0000000002fa1220] rfps: 28.916667 0.003603
    [mpegts @ 0000000002fa1220] rfps: 29.000000 0.003056
    [mpegts @ 0000000002fa1220] rfps: 29.083333 0.002553
    [mpegts @ 0000000002fa1220] rfps: 29.166667 0.002096
    [mpegts @ 0000000002fa1220] rfps: 29.250000 0.001684
    [mpegts @ 0000000002fa1220] rfps: 29.333333 0.001316
    [mpegts @ 0000000002fa1220] rfps: 29.416667 0.000994
    [mpegts @ 0000000002fa1220] rfps: 29.500000 0.000717
    [mpegts @ 0000000002fa1220] rfps: 29.583333 0.000486
    [mpegts @ 0000000002fa1220] rfps: 29.666667 0.000299
    [mpegts @ 0000000002fa1220] rfps: 29.750000 0.000157
    [mpegts @ 0000000002fa1220] rfps: 29.833333 0.000061
    [mpegts @ 0000000002fa1220] rfps: 29.916667 0.000009
    [mpegts @ 0000000002fa1220] rfps: 30.000000 0.000003
    [mpegts @ 0000000002fa1220] rfps: 60.000000 0.000012
    [mpegts @ 0000000002fa1220] rfps: 120.000000 0.000047
    [mpegts @ 0000000002fa1220] rfps: 240.000000 0.000187
    [mpegts @ 0000000002fa1220] rfps: 29.970030 0.000000
    [mpegts @ 0000000002fa1220] rfps: 59.940060 0.000000
    [NULL @ 0000000002fa40e0] start time for stream 1 is not set in estimate_timings_from_pts
    [mpegts @ 0000000002fa1220] stream 1 : no TS found at start of file, duration not set
    [mpegts @ 0000000002fa1220] Could not find codec parameters for stream 1 (Audio: aac ([15][0][0][0] / 0x000F), 0 channels, fltp): unspecified sample rate
    Consider increasing the value for the 'analyzeduration' and 'probesize' options
    [mpegts @ 0000000002fa1220] After avformat_find_stream_info() pos: 0 bytes read:7475920 seeks:4 frames:7
    Input #0, mpegts, from 'concat:Part1.ts|Part2.ts':
    Duration: 00:04:08.15, start: 1.500100, bitrate: 193113 kb/s
    Program 1
    Metadata:
    service_name : Service01
    service_provider: FFmpeg
    Stream #0:0[0x100], 7, 1/90000: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 3840x2160 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
    Stream #0:1[0x101](und), 0, 1/90000: Audio: aac ([15][0][0][0] / 0x000F), 0 channels, fltp
    Successfully opened the file.
    Parsing a group of options: output file full.mp4.
    Applying option c (codec name) with argument copy.
    Applying option bsf (A comma-separated list of bitstream filters) with argument aac_adtstoasc.
    Opening an output file: full.mp4.
    [mp4 @ 0000000005b727e0] Codec for stream 0 does not use global headers but container format requires global headers
    Output #0, mp4, to 'full.mp4':
    Metadata:
    encoder : Lavf56.40.101
    Stream #0:0, 0, 1/90000: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, 29.97 fps, 29.97 tbr, 90k tbn, 90k tbc
    Stream mapping:
    Stream #0:0 -> #0:0 (copy)
    Press [q] to stop, [?] for help
    [NULL @ 0000000002fc79a0] non-existing SPS 0 referenced in buffering period
    frame= 356 fps=0.0 q=-1.0 size= 139556kB time=00:00:11.74 bitrate=97338.0kbits/s
    frame= 758 fps=666 q=-1.0 size= 295703kB time=00:00:25.15 bitrate=96285.7kbits/s
    frame= 1143 fps=691 q=-1.0 size= 447239kB time=00:00:38.00 bitrate=96403.4kbits/s
    frame= 1518 fps=700 q=-1.0 size= 592016kB time=00:00:50.51 bitrate=96003.0kbits/s
    frame= 1900 fps=708 q=-1.0 size= 743082kB time=00:01:03.26 bitrate=96222.2kbits/s
    frame= 2279 fps=716 q=-1.0 size= 888636kB time=00:01:15.90 bitrate=95900.2kbits/s
    frame= 2653 fps=720 q=-1.0 size= 1034896kB time=00:01:28.38 bitrate=95916.2kbits/s
    frame= 2997 fps=716 q=-1.0 size= 1167277kB time=00:01:39.86 bitrate=95751.2kbits/s
    frame= 3347 fps=712 q=-1.0 size= 1305167kB time=00:01:51.54 bitrate=95853.2kbits/s
    frame= 3726 fps=715 q=-1.0 size= 1451773kB time=00:02:04.19 bitrate=95763.4kbits/s
    frame= 4106 fps=719 q=-1.0 size= 1598757kB time=00:02:16.87 bitrate=95689.4kbits/s
    frame= 4481 fps=721 q=-1.0 size= 1744921kB time=00:02:29.38 bitrate=95689.8kbits/s
    frame= 4859 fps=722 q=-1.0 size= 1894282kB time=00:02:41.99 bitrate=95792.7kbits/s
    frame= 5237 fps=725 q=-1.0 size= 2039336kB time=00:02:54.60 bitrate=95678.7kbits/s
    frame= 5621 fps=726 q=-1.0 size= 2189085kB time=00:03:07.42 bitrate=95683.1kbits/s
    frame= 5948 fps=722 q=-1.0 size= 2315726kB time=00:03:18.33 bitrate=95650.1kbits/s
    frame= 6332 fps=723 q=-1.0 size= 2466641kB time=00:03:31.14 bitrate=95701.0kbits/s
    [mpegts @ 0000000002fa1220] Continuity check failed for pid 17 expected 11 got 0
    [mpegts @ 0000000002fa1220] Continuity check failed for pid 0 expected 1 got 0
    [mpegts @ 0000000002fa1220] Continuity check failed for pid 4096 expected 1 got 0
    [mpegts @ 0000000002fa1220] Continuity check failed for pid 256 expected 11 got 0
    timestamp discontinuity -217217000, new offset= 215716900
    [mpegts @ 0000000002fa1220] Continuity check failed for pid 257 expected 7 got 0
    frame= 6697 fps=723 q=-1.0 size= 2610775kB time=00:03:43.32 bitrate=95769.2kbits/s
    frame= 7087 fps=725 q=-1.0 size= 2760093kB time=00:03:56.33 bitrate=95671.7kbits/s
    frame= 7466 fps=726 q=-1.0 size= 2907285kB time=00:04:08.98 bitrate=95655.4kbits/s
    frame= 7799 fps=722 q=-1.0 size= 3037167kB time=00:04:20.09 bitrate=95659.8kbits/s
    frame= 8183 fps=723 q=-1.0 size= 3186337kB time=00:04:32.90 bitrate=95646.4kbits/s
    frame= 8563 fps=724 q=-1.0 size= 3335382kB time=00:04:45.58 bitrate=95675.3kbits/s
    frame= 8939 fps=725 q=-1.0 size= 3481007kB time=00:04:58.13 bitrate=95650.6kbits/s
    frame= 9319 fps=726 q=-1.0 size= 3630585kB time=00:05:10.81 bitrate=95690.9kbits/s
    frame= 9692 fps=726 q=-1.0 size= 3775764kB time=00:05:23.25 bitrate=95685.9kbits/s
    frame=10061 fps=727 q=-1.0 size= 3919880kB time=00:05:35.56 bitrate=95693.3kbits/s
    frame=10444 fps=727 q=-1.0 size= 4068781kB time=00:05:48.34 bitrate=95684.4kbits/s
    frame=10814 fps=728 q=-1.0 size= 4213365kB time=00:06:00.69 bitrate=95693.1kbits/s
    frame=11191 fps=729 q=-1.0 size= 4358538kB time=00:06:13.27 bitrate=95654.3kbits/s
    frame=11570 fps=729 q=-1.0 size= 4505889kB time=00:06:25.91 bitrate=95647.7kbits/s
    frame=11958 fps=730 q=-1.0 size= 4654649kB time=00:06:38.86 bitrate=95598.4kbits/s
    frame=12337 fps=730 q=-1.0 size= 4803656kB time=00:06:51.51 bitrate=95626.9kbits/s
    frame=12722 fps=730 q=-1.0 size= 4952411kB time=00:07:04.35 bitrate=95603.8kbits/s
    frame=13109 fps=732 q=-1.0 size= 5095605kB time=00:07:17.27 bitrate=95463.2kbits/s
    frame=13495 fps=730 q=-1.0 size= 5242899kB time=00:07:30.14 bitrate=95412.3kbits/s
    frame=13865 fps=730 q=-1.0 size= 5385034kB time=00:07:42.49 bitrate=95383.0kbits/s
    No more output streams to write to, finishing.
    frame=13950 fps=731 q=-1.0 Lsize= 5418079kB time=00:07:45.33 bitrate=95383.4kbits/s
    video:5417731kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.006439%
    Input file #0 (concat:Part1.ts|Part2.ts):
    Input stream #0:0 (video): 13950 packets read (5547756075 bytes);
    Input stream #0:1 (audio): 0 packets read (0 bytes);
    Total: 13950 packets (5547756075 bytes) demuxed
    Output file #0 (full.mp4):
    Output stream #0:0 (video): 13950 packets muxed (5547756075 bytes);
    Total: 13950 packets (5547756075 bytes) muxed
    0 frames successfully decoded, 0 decoding errors
    [AVIOContext @ 0000000005b72ee0] Statistics: 34 seeks, 176318 writeouts
    [AVIOContext @ 0000000002faabc0] Statistics: 5997571400 bytes read, 4 seeks
    SETUP: Win7 x64, Intensity Shuttle, 12 GB RAM, i7-970, x58 Gigabyte GA-X58A-UD3R
    Les Garten replied 11 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
