Activity Forums Adobe Premiere Pro Computer specs in regards to CS4
  • Computer specs in regards to CS4
    Posted by Adam Jungemann on September 24, 2010 at 3:17 pm
    Hello,
    I am currently editing HD footage (1080p) shot on a Canon 7D (yes, I converted it so it works smoothly in premiere). I used to convert to SD because i didn’t think it mattered since I would burn it to DVD in SD in the long run anyway BUT now I am uploading videos online so the HD is the way to go.
    When I edited in SD, everything worked good. My computer was fast and snappy and I had minimal crashes with Premiere (maybe 1 every 3 weeks) but now that I switched to HD, my computer is laggy and crashes if I try to move too fast. I realize my problem is that HD footage takes more computing power but I wondered what component was my “bottleneck”.
    I have a Dell Inspiron something or other… its about 3 yrs old so nothing too special. It has 3GB RAM, an intel Quadcore processor (still on 32 bit), and I believe an NVIDIA G-Force 512mb graphics card. I am running dual monitors (1 in 1920 x 1080) and the other is via VGA cable. Do I need to provide my keyboard specs as well? I kid… besides, its a logictech wireless…
    the geek squad at best buy said that my graphics card was my limiting factor but I didn’t think the graphics card played much into your processing tasks.
    Thanks for your help!
    Eric Monroe replied 15 years, 11 months ago 4 Members · 4 Replies
  • Jon Barrie
    September 24, 2010 at 10:19 pm
    Key areas with your system that can bottle neck.
    – RAM (which is limited in 32bit OS)
    – 32bit OS (win7 is very good)
    – separate drives for media (don’t use the OS drive as your media drive too)
    – read write speed of media drive (RAID 0 or 5 can get smooth datarates for most HD editing)
    – compressed or uncompressed codecs
    Your quadcore CPU can do the job, but i7 would be better. CS5 can edit native DSLR video and is 64bit so can make proper use of a 64bit OS and available ram.
    Hope this helps.
    – Jon Barrie
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Eric Monroe
    September 26, 2010 at 4:59 pm
    Hi Adam,
    i just went through this same thing recently….I have a custom built Core-2 Quad PC with 8 gig of ram, GTX260 1 gig graph card, 2 raid-0 arrays for running scratches and media files separately,windows 7 64-bit and also a brand new Mac-mini core 2 with 8 gig of ram….both machines run SD footage FANTASTIC! with minimal crashes or lock-ups. Moving to HD has been another cup of tea.
    Through tons of tests with my machines and others, I have found that on my systems personally, my bottleneck has been processor. I brought up the cpu/memory monitor in win7 on my pc and was using only 7% of the 8 gigs of ram memory, but processor was pegged at 100% and it still wasn’t enough. As Jon said, many different things can bottleneck a system, I was frustrated at first when I found out that my 2.4 Quad would not do the trick. My friend’s new 6-core AMD phenom 2 however has plenty of power, and edits AVCHD natively without a prob at all…..on only 4 gig of ram and a 5-year old 8800 graph card. (my old one, that i beat up on for 3 years, still keep tickin…gotta love that)
    HD is just a “bear” I have learned the hard way through frustration and testing that you just gotta have power to play with HD.
    Hope this helps.
    Eric
  • Brian Louis
    September 27, 2010 at 7:05 pm
    If you want to run footage on a system like yours you should look into using a intermediate codec like Cineform’s Neoscene,
    https://www.cineform.com/neoscene/
  • Eric Monroe
    September 27, 2010 at 11:09 pm
    Hey Brian,
    I tried the free download of Cineform, and didn’t have much luck with it. Although admittedly it was right in the beginning of my AVCHD “adventures” so maybe I wasn’t doing something correctly.
    I ordered my AMD 6-core proc, ASUS Crossfire board (with Sata 6 & USB 3) and 16 GB of 1333 mghz RAM, so this way I can jump straight into editing AVCHD natively and bypass the transcoding.
    Thanks for your input though, maybe I will check out neoscene again though, just for the simple fact of “knowing”
    Cheers
