Activity › Forums › VEGAS Pro › Computer specs and Vegas 8 Platinum
  • Computer specs and Vegas 8 Platinum
    Posted by William Birchall on June 9, 2008 at 9:09 am
    I have just purchased a Sony HDR-TG3E HD Camcorder and am considering trialling the Sony Vegas 8 Platinum. I want to capture in AVCHD and output to disk at the highest level that the software allows and to have 5.1 audio. I would probably be editing a maximum of 1 hours high quality video. I need to know whether my system is up to the editing task. I have:-
    Sony Vaio VGN-AR21S Full HD Laptop
    CPU Intel Core 2 Duo Processor T7200 2.GHZ
    Memory 2GB DDR2 SDRAM
    HDD 200Gb
    Blu Ray disk drive
    Graphics NVidia GeForce Go 7600GT with 256MB dedicated video memory
    External HDD Lacie 500GB
    OS Windows Media Center 2005
    I would be grateful if someone could comment on the suitability or otherwise of this setup, for the anticipated level of editing.
    William Birchall replied 18 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Rasnic
    June 12, 2008 at 4:56 pm
    You will want to ensure that your bluray drive is actually a burner. The AVCHD format is hard to edit currently but VASST makes a program called AVC Upshift that will convert the files to M2T files for better editablity.
    Of course, you could always use more processor power but yours should be fine if you convert the files first. You can try AVCHD first and then downlaod the AVC Upshift trial and compare to see if it benefits you.
    Also, I don’t use Platinum- you may want to look into the special for Vegas pro 8 from BHphotovideo.com- it may be more worth your while after you run the trial for platinum (and 8 pro).
    j razz
  • William Birchall
    June 22, 2008 at 3:08 pm
    Jeremy
    Apologies for not replying sooner but my Wife and I have just returned from a cruise to Norway. Thanks for your helpful reply. My Blu Ray Disk Drive is a burner and I have Ulead’s BD Disk Recorder software.
    Regards
    Bill Birchall
