Activity Forums Apple Final Cut Pro Legacy computer monitor not matching client monitor…timing
  • computer monitor not matching client monitor…timing
    Posted by Joe Procopio on August 6, 2008 at 12:45 pm
    so my output through AJA Kona is not matching my canvas…canvas is a frame delayed…can we compenate this to get them to match so my editors don’t freak out that their audio is ot of sync? audio and video monitoring is through Kona…
    FCP S2, 8 core Mac, blah blah blah, thanks!
    Broadway Video, NYC
    AVID/FCP editor/engineer
    Joe Procopio replied 18 years ago 2 Members · 2 Replies
  • Jerry Hofmann
    August 6, 2008 at 12:54 pm
    By changing the frame offset value in Final Cut Pro, you can compensate for the delay
    between your computer display and external video and audio outputs. Frame offset is
    active only when your sequence real-time effects are handled by Final Cut Pro. For
    information about specifying settings in the Effect Handling tab of the System Settings
    window, see Volume III, Chapter 28, “Using RT Extreme.”
    To set the frame offset between the computer display and the external video and
    audio outputs:
    1 Choose Final Cut Pro > System Settings.
    2 Click the Playback Control tab.
    3 Enter a number of frames in the Frame Offset number field.
    Frame offset can be any whole number between 0 and 30. The default value is 4. For
    example, if a video monitor connected to your DV camcorder shows your program four
    frames later than your computer display, a frame offset of 4 will synchronize the two.
    Note: Depending on your external monitor configuration, you may need to experiment
    with frame offset values to synchronize the external monitor and the computer display.
    4 Click OK.
    5 Play your video in the Canvas or Viewer and compare the video offset between your
    external monitor and your computer display.
    6 If the computer display and external monitor are still not synchronized, repeat steps
    1 through 5 using different frame offset values until the display and monitor are in sync.
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Joe Procopio
    September 26, 2008 at 7:36 pm
    totally forgot I asked this question….
    so does the frame offset do anything to your output to tape? or will your output be frame accurate?
    most importantly would be inserting to tape…if you’re offset, does that affect timecode?
    which view is offset, the canvas view, or the Kona output?
    Broadway Video, NYC
