Activity Forums Blackmagic Design Computer HDMI->ShuttleProUSB3->LaptopUSB3 not working
  • Computer HDMI->ShuttleProUSB3->LaptopUSB3 not working
    Posted by Derick Boe on March 28, 2013 at 6:13 pm
    I’ve had this Intensity Shuttle USB3 device for about a year now and just got a new desktop so I want to try it out.
    I have the HDMI cable plugged into my video card and set my computer to Clone desktop, so all outputs on the video should be the same. I’ve set my resolution to 1280×720@60hz.
    I’ve connected it to the Shuttle and from there, plugged the USB cable into my Renesas PCCard54 To USB 3 card on the laptop.
    The software recognizes that it’s plugged in, the Media Express shows Intensity Shuttle with a checkmark.
    However I get no video or audio in the preview. If I try to capture, it just captures nothing.
    I’ve set the project preferences to 1280x720p@60fps. My games are running at 720p, but nothing is getting through.
    The laptop is an Alienware M17x R1. It doesn’t have the intel x58 chipset, it’s running Nvidia chipset, which is crap.
    However, I’ve tested this USB 3.0 card with a fast flash drive, and I get over 200 MBps read and 180 MBps write speeds, so there’s plenty of bandwidth there.
    I have 2 750 GB hybrid drives running in RAID0, and the Disk test utility says I can do up to 1080i recording at 60fps.
    Is this just not going to work? I can’t use Fraps as it lags my computer too much.
    Computer specs are
    Processor Manufacturer: Intel
    Processor Version: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
    External Clock: 190 MHz
    Maximum Clock Supported: 2800 MHz
    Current Clock: 3610 MHz
    CPU Socket: Populated
    CPU Status: Enabled
    Processor Type: Central Processor
    Processor Voltage: 1.2 V
    Processor Upgrade: Unknown (1)
    Socket Designation: LGA1366
    ASUS P6X58D PREMIUM
    Intel X58 (Tylersburg 36S) + ICH10R
    6 GB DD3 triple Channel
    Derick Boe replied 13 years, 5 months ago 2 Members · 5 Replies
  • Mike Squires
    April 2, 2013 at 4:07 pm
    Did you go into the Blackmagic Control Panel (under Windows Control Panel/Hardware and Sound) and set the input for HDMI, and the resolution for 1280×720? The settings have to be done in both the Blackmagic Control Panel, and in Media Express.
  • Derick Boe
    April 2, 2013 at 4:16 pm
    Omg that’s brilliant! No I didn’t even know about that it’s not mentioned anywhere! I’ll try that in a few minutes.
  • Derick Boe
    April 2, 2013 at 5:17 pm
    Okay getting somewhere. I set it to 1280×720@60 in the control panel. Now when I plug it into my computer and run media express, I get a message saying that I need to update my Blackmagic device. So I tell it to. It says “The software on your Intensity Shuttle was updated successfully” and to unplug power and usb to restart it. So I do then plug it back in after 45 seconds and then press OK on that prompt.
    I then have to close Media Express because it no longer detects a device plugged in. So I close and re-open it and now it says: “Blackmagic hardware could not be found in your system. Please check the installation.”
    If I unplug then plug the device back in then open Media Express it opens, detects the device and again says it needs it’s drivers updated.
    Stuck in a loop here.
    At one point I did see something in the preview pane just before Media Express said I need to update the device, so I think it will work now, I just have to get around this moronic song and dance.
  • Mike Squires
    April 3, 2013 at 1:28 am
    A couple of other people have had that same problem. Try uninstalling the Blackmagic software, reboot, re-install the software, reboot again, and plug in the device.
  • Derick Boe
    April 8, 2013 at 1:16 pm
    Sorry for the late reply, I did that several times now, it happens every time but I will try it again.
    So frustrating.
