Activity › Forums › Apple Final Cut Pro Legacy › Compressor_Movie Factory mpg2 won’t play in MF6
  • Compressor_Movie Factory mpg2 won’t play in MF6
    Posted by Leonard Frankford on February 1, 2010 at 3:16 pm
    I need to export an mpg2 file with imbedded audio for import into Ulead Movie Factory 6 for DVD authoring. Compressor has a preset for this. When I bring the file into Movie Factory, it won’t play. It just sits on the first frame. I haven’t tried the PC mpg2 file preset; it looks like it’s the same parameters as the MF file. Anyone have experience with this? Thanks.
    Leonard
    Leonard F.
    Leonard Frankford replied 16 years, 8 months ago 1 Member · 1 Reply
  • Leonard Frankford
    February 1, 2010 at 5:55 pm
    Movie Factory requires the audio be embedded with the mpg2. It will not combine them in the authoring. I’ve used this program for years, first MF 3 and now MF 6. It’s a consumer program that is very easy to use and does a nice job. But I’ve never used it with FCP before. I was happy to see Compressor already had a preset for this, but it doesn’t seem to work once I import it into Movie Factory.
    Leonard F.
