Activity › Forums › Apple Final Cut Pro Legacy › Compressor/Limiter Filter
  • Compressor/Limiter Filter
    Posted by Braden Curtis on July 6, 2005 at 2:10 pm
    I’m working with audio that a client captured on an XL2. Unfortunately, it was done in 4channel/32k, 12-bit mode. And, no wireless mic was used – all audio of the single presenter and audio were captured by the camera-mounted shotgun.
    So, the presenter’s levels are extremely low, and the laughs, coughs and claps of people seated near the camera are very high. I’m trying to use the Compressor/Limiter filter, but it doesn’t seem to be working the way I think it should.
    There are two mono tracks. I’ve set the threshold at -6dB. The filter seems to do the best job when it’s applied to only one of the 2 channels, and it doesn’t seem to matter which channel the filter is applied to.
    Am I doing something wrong?
    Braden Curtis
    Jerry Hofmann replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 6, 2005 at 5:25 pm
    Gotta say that what you are attempting isn’t easy to fix. Got Soundtrack Pro? That has features that will do the job a ton better than FCP can do…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
