Activity Forums Apple Final Cut Pro Legacy Compressor will not “submit” job
  • Compressor will not “submit” job
    Posted by Corby Anderson on November 22, 2010 at 7:35 pm
    Hi there. I am having a problem with compressor, and wondering if someone can help.
    I sent a project from Final Cut to Compressor. Compressor opens fine, allows me to add the destination and compression settings fine, and everything seems normal until I go to “submit”. Then, it asks me to save. When I give it a name and hit “submit” within the save menu, it goes right back to the menu before.
    No job is started, it just sits there.
    Anyone? Help!
    Rene Hoeksema replied 13 years, 4 months ago 5 Members · 5 Replies
  • Mike Kahn
    November 22, 2010 at 7:41 pm
    If you open the batch monitor, is there a job being processed?
  • Corby Anderson
    November 22, 2010 at 7:44 pm
    Actually, yes. I will see what happens when the job that is processing completes. Maybe my windows just got rearranged. Thanks for the heads up.
    C
  • Rafael Amador
    November 22, 2010 at 8:15 pm
    The best way to see if Compressor, or any other application, is running, is the Activity Monitor.
    You may try this to fix Compressor:
    https://www.digitalrebellion.com/compressor_repair.htm
    rafael
    http://www.nagavideo.com
  • Bret Williams
    November 22, 2010 at 8:48 pm
    You can open the history window in compressor to see the progress as well if you don’t want to open the batch monitor.
  • Rene Hoeksema
    May 14, 2013 at 9:22 am
    To whoever will read this; This post, the repiar, just saved my day!
