Activity Forums Apple Final Cut Pro Legacy Compressor vs Export w/ QT
  • Compressor vs Export w/ QT
    Posted by Kris Mehaffey on March 21, 2007 at 1:53 am
    Is there any noticeable quality difference in quality using Compressor vs using Quicktime conversion with this setup:
    Codec: DV/DVCPRO NTSC, Compressor Quality: Best
    Audio: Linear PCM, Stereo, 48,000 kHz, Render Quality: Best, Sample Size 16
    the above is the recommended export setup at work, but I dont want to get shafted for turning in subpar projects. I’ve been having trouble with Compressor lately, and if its easier and more convenient to use Quicktime, I’d rather use that.
    Steven Lambion replied 19 years, 5 months ago 3 Members · 2 Replies
  • Rafael Amador
    March 21, 2007 at 2:24 am
    Kris.
    What do you want export or convert to DVNTSC?
    rafael
  • Steven Lambion
    March 21, 2007 at 6:57 am
    It sounds like you should just use: MenuBar -> File -> Export -> Quicktime Movie…
    This uses the same settings as the sequence or clip your exporting so it’s faster and at best quality. It can be a little over sized though.
    I’m not fully sure what the orignal sequence is so I don’t kow if your trying to switch to a different compression or not.
    Video Specialist
    Apple Developer
    Owner of GranitWorks
