Activity › Forums › Apple Final Cut Pro Legacy › Compressor Very Slow & FCP/Motion Sluggish on New Quad
  • Compressor Very Slow & FCP/Motion Sluggish on New Quad
    Posted by Sam on July 28, 2006 at 2:38 am
    Hello Fellow Editors
    A little confused here!
    Installed FCP Studio 5.04 with updates on a brand new Quad.
    Cut a 10 min DV sequence with couple filters and speed changes to each clip; about 25 clips.
    When I had Motion and FCP started at the time while modifying a motion project, the computer froze several times while making the change. Very simple motion project with a simple text and thats it. Either FCP or Motion wiould freeze and would need a Force Quit.
    #2: Exporting the 10 min sequence outta FCP says 1 hour 30 mins. Now I know that I have exported projects much much faster on other Dual 2.0’s. Any idea?
    My configuration:
    Quad
    4.5 GB RAM
    Lacie 500GB Capture
    AJA IO/Kona3 (but capturing using Kona3->DV for this one)
    ACD 23″ Display
    nVidia 7800GT Video
    Should I do a clean Install? The computer is BRAND NEW out of the box and causing all this.
    Thanks for the help
    Sam.
    Mark Maness replied 20 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • 13 Create COW Profile Image
    13
    July 28, 2006 at 4:41 am
    What are your export settings
  • Sam
    July 28, 2006 at 5:08 am
    The Export settings are the Default DVD 120 Min. Best Settings with AIFF or with Dolby 2.0 AC3.
  • Mark Maness
    July 28, 2006 at 2:03 pm
    Two questions for you, Sam.
    1. What kind of memory is installed in your system? Did Apple put it in or is it a third party memory that was bought off of the internet?
    2. Under System Preferences, has Engery Saver – Options – Processor Performance been set to Highest?
    The reason I ask these things… Memory is not always reliable from other sources unless it comes for the major manufacturers and specifically designed for your particular Mac. The other… I ran into system slow downs myself at first until I found out there was a seeting in Energy Saver for processor speed. It made a HUGE difference for me, and I have a dual 2.7 processor, not the Quad.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Ernie Santella
    July 28, 2006 at 3:02 pm
    Where can you find the option for processor speed in the Energy Saver section? I do remember they used to have this on older OS, but on 10.4?
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
  • Ernie Santella
    July 28, 2006 at 3:13 pm
    Ooops, my bad, found it. As Rosanna Danna says… “Never mind”
    Ernie Santella
  • Sam
    July 29, 2006 at 6:10 pm
    Hi Wayne
    I actually have Kingston Memory installed which was made for Mac I believe. We have used Kingston memory for other Macs as well and didn’t have a problem.
    The processor speed is set to Automatic for Energy Saver. Is it suppose to be otherwise?
    Sam
  • Mark Maness
    July 31, 2006 at 1:26 pm
    Hey Sam,
    The memory should be fine but every now and then even the best manufacturers can have some faulty product. And to answer your second statement, set your processor performance to Highest in Energy Saver, it will make a major difference.
    Wayne Carey
    Schazam Productions
  • Sam
    July 31, 2006 at 1:59 pm
    Wayne Thanks
    Are there any programs that will test the memory to see if its ok?
    can we download them from somewhere
    thans
    sam
  • Mark Maness
    August 2, 2006 at 1:27 pm
    If you have Tech Tool Pro, it will test memory. If you don’t have it, I would suggest you purchase a copy. Its an excellent program to have for just such a problem as yours.
    Wayne Carey
    Schazam Productions
