Compressor-The achilles heel of my workflow….
As an AVID editor over ten years, I’ve used Autodesk Cleaner XL and Sorensen Squeeze as two consistent programs to compress various forms of video.
I have never experienced the inconsistency in compression software like I have with Compressor…dear god I wish I could get it to work well.
I’ve followed the advice of a previous thread here and tried a custom install of Compressor but in doing so the screen showed me the following:
As shown above, the install screen did not give me the option of solely selecting “compressor”.
So I thought it might be a matter of highlighting Compressor since I couldn’t check that box by itself.
Well everything re-installed and 3.5 hours later I still have the same problem with Compressor. It just sits there and doesn’t Compress. Before that it would tell me that I would need to select a destination or compression setting AFTER I had already done so.
I tried the link to the Compressor fix/patch and that didn’t work. So I’m really at a loss. Yes, I’ve been going through the threads but this is getting to be major drag.
Any ideas from here or insight into why I can’t install Compressor by itself?
