Activity Forums Apple Final Cut Pro Legacy Compressor slow (50% CPU, <10M disk)
  • Compressor slow (50% CPU, <10M disk)
    Posted by Ben Edwards on April 2, 2011 at 12:57 pm
    I amusing Compressor to encode iMovie DV to FCP DV PAL. I would expect it to be either CPU bound (i.e. >90% CPU) or Disk bound (I get > 15MB/s generally) but it seems to be neither.
    I am intact getting a average CPU load across 4 cores of under 50% and disk seems to average around 5MB/s.
    any ideas what is going on, have I missed something/set something up wrong.
    I have a Mac Pro with 4 3Ghz CPUs. The source footage is on a external USB drive and target is local.
    Regards,
    Ben
    Ben Edwards – Freelance Filmmaker
    https://www.funkytwig.com
    Ben Edwards replied 15 years, 5 months ago 3 Members · 3 Replies
  • Zane Barker
    April 2, 2011 at 4:46 pm
    For compresor to take full advantage of your processors you need to set a a virtual cluster. Search the web there is good info out there on how to do this.
    [Ben Edwards] “The source footage is on a external USB drive and target is local.”
    This is going to slow things down. USB works in bursts of data. Having a constant stream of data is MUCH better. The general rule is NEVER use USB for video.
    **Hindsight is always 1080p**
  • Paul Jay
    April 2, 2011 at 6:27 pm
    Copy source footage to your sata drive
    In system preferences-> qmaster
    Select compressor->then instances
    You could choose 4 but 3 is recommended.
    Start sharing.
    Now when you submit a batch.
    Choose cluster.
    Done
  • Ben Edwards
    April 4, 2011 at 4:50 pm
    I went into Qmaster and set to compressor Service to have 2 instances (I am Quad core). I submitted to the Clistername I had set up. It looks like everything work except CPU usage is even lower and it does not seem to be creating any output files.
    Any idea what Iam doing wrong?
    Ben
