Compressor settings
I have a prores qt file of my short film that I need to convert for a film fest. These are the spec requirements that they emailed me:
-digital container format MP4
-video codec H.264 (also known as MPEG-4 part 10 or MPEG-4 AVC)
-video resolution Full HD PAL 1920 x 1080 aspect ratio 16:9 (1080p) or 1280 x 720 aspect ratio 16:9 (720p) without black bars
-progressive (non Interlaced)
-frame-rate 25fps
-audio stereo MP3/AAC 48kHz, 256kbps
-video bit-rate not more than 10Mbps
-the best option is to use 2pass encodingI’m using Compressor. Could you tell me the exact settings I should be using? I know my way around Compressor *fairly* well. Should I use the mpeg-4 setting or the h264 setting? He mentions PAL above? Does that just mean choose 25p? The more specific you can be, the better. My prores file is 422HQ 1920×1080. Was shot at 24p. It’s 18GB. The movie is 15 minutes. The guy I’m dealing with said the file I convert for them should end up being about 1.5-2GB in size.
Thanks in advance. Really appreciate this!
