Activity › Forums › Apple Final Cut Pro Legacy › Compressor renaming
  • Compressor renaming
    Posted by Eli Mavros on May 30, 2007 at 12:57 am
    Is there any way for me to just export something from FCP with compressor without it adding the prefix (batch name) and suffix (compressor type) to all the movies? I just want them to be named exactly what my sequences are named. It is really annoying for me to have to change all of these after they get exported before I can post them for the client. Am I missing something? It sounds like this should just be some easy setting in the prefs.
    Best,
    Eli
    Sean Oneil replied 19 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • John Pale
    May 30, 2007 at 2:02 am
    You can change the naming convention Compressor uses in the Destination pane.
  • Eli Mavros
    May 30, 2007 at 2:28 pm
    Thanks John,
    But I was wondering if there was a way to just not have the program add all that stuff…doing it the way you described still requires me to “fix” each one individually, no? I just want it not to add that stuff and keep the name the same.
    Best,
    Eli
  • John Pale
    May 30, 2007 at 2:58 pm
    [Eli Mavros] “doing it the way you described still requires me to “fix” each one individually, no? I just want it not to add that stuff and keep the name the same.”
    No. You can have it name the clips exactly the way you want automatically, every time.
    Just select the destination preset you create, just like you select an encoding preset and you are good to go.
  • Eli Mavros
    May 30, 2007 at 3:39 pm
    I feel like a complete idiot, but I don’t see where you are talking about. I see in the destination area that I can set where the movies go, but not any preferences on how they are named. Where exactly is this pref?
    Eli
  • John Pale
    May 30, 2007 at 4:53 pm
    You are not an idiot. Its kind of clunky and not obvious. Dont know if its improved in Compressor 3 yet.
    Create a custom Destination. Click on that custom destination in the Destination Pane.
    Go to the Inspector and look in the space called Template. There is a pulldown menu it. It gives you various choices of what to include in the file name…or you can just select everything in the box and delete it and it will leave it the same as the source file.
  • Sean Oneil
    May 31, 2007 at 7:31 pm
    John,
    Eli is right. There’s something wrong with naming in version 3. I’m trying to figure it out right now. It’s really screwed up.
  • Sean Oneil
    May 31, 2007 at 7:37 pm
    Okay I figured it out. After doing the upgrade, Compressor 3 remembers your old Compressor 2 default destination. But the destination is corrupted. You need to throw it away and create a new one.
