Activity Forums Apple Final Cut Pro Legacy Compressor Preview problems
  • Compressor Preview problems
    Posted by Raven Plenty on August 25, 2008 at 10:06 pm
    1. Compressor’s Preview seems to be unable to display 16:9 content as 16:9. Checking “Square pixels” properly displaystrue 720×480, but unchecking it results in 640×480, regardless of the selected aspect ratio. The resulting file is 16:9 though, that’s good.
    2. Compressor’s Preview does not seem to preview the compression settings, it only shows any size changes, i.e. downsizing, cropping, etc. (I care more about this than the aspect ratio issue.)
    Anyone else notice these? Bugs? Compressor 2.0.1 by the way.
    Raven Plenty replied 18 years ago 2 Members · 2 Replies
  • Jeremy Garchow
    August 25, 2008 at 10:29 pm
    The best way to render a preview out of compressor is to set an in and out and then encode it (say for 1 second).
    Also, if you notice the two boxes at the top of the compressor preview box, you can hit the other one and get a correct PAR.
    Jeremy
  • Raven Plenty
    August 25, 2008 at 10:39 pm
    In other words, Preview is fairly useless. Fair enough.
    Could’ve sworn I tried clicking those top right boxes and it didn’t work before – that’s why I bothered posting about it. Worked this time though, go figure.
    Thanks Jeremy.
