Activity Forums Apple Final Cut Pro Legacy Compressor or premiere for standards conversion?
  • Compressor or premiere for standards conversion?
    Posted by Tim Maloney on February 8, 2010 at 8:08 pm
    I want to convert a lot of h264 from a contour HD miniature camera. It shoots @29.97 and I\’ve been using compressor to convert the files to 50i. Takes a long time even with an October tower.
    Is compressor using the eight processors?
    Could I use Cs4 as it\’s 8 core optimized? Which part of cs4 is like compressor?
    Best
    Tim Maloney
    Axis Films
    Tim Maloney
    Managing Director
    Axis Films Melbourne Australia
    tim@axisfilms.com.au
    Joe Lloyd replied 16 years, 7 months ago 2 Members · 1 Reply
  • Joe Lloyd
    February 8, 2010 at 8:18 pm
    Have you setup a quick cluster for compressor to work in? I personally feel that Compressor does a better job of standards conversion than Adobe Media Encoder. In compressor, make sure you’re using Frame Controls and Rate Conversion is at Better or Best if you have the time.
    Maybe some others can chime in.
    Curbsyde Productions
    Australia Inside Out – Coming Spring 2010
