Activity Forums Apple Final Cut Pro Legacy Compressor Not Compressing
  • Compressor Not Compressing
    Posted by Melinda Hess on November 14, 2008 at 5:56 pm
    I’ve been working on a series of videos that vary from 40 min-1:30. They are all SD, DV videos. I export from FCP > Self Contained QT movie, then import into Compressor. For about a year, I’ve had NO problem compressing the files- both as individual movies, or running an overnight batch of several files. I recently ran a batch of about 4 movies, and in the morning came into the studio to find not only that my computer had crashed, no files had compressed, but the CPU was very loud – much noisier than usual. So I called Apple- they basically said I had to do a de-install, then re-install Compressor. I did it exactly according to Apple specs.
    When it was complete- a couple of hours later, compressor did work, and my computer was no longer making a loud noise. I loaded a batch of 2 files, and while it didn’t crash the computer, it took an inordinately long time to compress- about 5 times longer than it should have. So called Apple, they said re-install again. So I did. Since then I have been successfully compressing movies- but ONLY 1 file at a time. This is obviously not an effective workflow.
    However, last night I set up 1 movie to encode, and came in this morning to find that it encoded the MPEG 2 file just fine- but hung up before it could encode the audio file.
    I have been encoding all these files with the same settings as the ones I was successfully batching a few months ago. I haven’t upgraded the OS, or any apps that I know of. Having to stop production to de-install and then re-install Compressor is very problematic and timely when I have a deadline- like I have now.
    Here are the stats of what I’m using & doing:
    Power Mac G5 –Dual 1.8 GHz, 3 GB
    Using External HDs eSata & FW 800 connectivity
    Final Cut 6.0.4 /Compressor 3.0.3
    In compressor> Apple’s MPEG-2 6.2Mbps 2-pass or 1 pass, depending on the length of videos & audio- Dolby Digital Professional 2.0 that is tweaked, normalization off
    Any thoughts or advice is most welcomed.
    Melinda
    Convivial Design
    Convivial Design Studio
    Abiquiu, NM 87510
    Zachary Stowasser replied 15 years, 11 months ago 4 Members · 3 Replies
