Activity Forums Apple Final Cut Pro Legacy Compressor Message “Unable to submit…”
  • Compressor Message “Unable to submit…”
    Posted by Grant Strac on March 9, 2009 at 3:06 pm
    -I’m running Power PC G5 with 10.5.6 and Final Cut Studio 2 all latest versions and up to date.
    I attempted to output a 30 min show, Export using compressor in Final Cut Studio 6.
    -Put DVD settings on and click submit. Error Message comes up saying “Unable to submit to queue. Please restart your computer or verify your Compressor instillation is correct.”
    -I restarted, shut down, and I KNOW my instillation is correct. Anyone have suggestions? Thank you
    Simon Scionka replied 16 years, 8 months ago 5 Members · 5 Replies
  • Rafael Amador
    March 9, 2009 at 3:31 pm
    Try reinstalling the Apple Qmaster.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mike Kahn
    March 9, 2009 at 3:59 pm
    I got this error a few weeks ago and had to reinstall Compressor and QMaster. I had been using Compressor for months with no problems. Not sure why it happens but it did. Follow instructions on uninstalling Compressor and download Pacifist to make the install easier.
  • Grant Strac
    March 9, 2009 at 4:01 pm
    Thank you both of you. I will try that
  • Mike Roberts
    July 21, 2009 at 8:04 pm
    Hey I had this problem… Re-installing the pro apps update from the apple website cleared it up without a hitch!
    https://www.apple.com/downloads/macosx/apple/application_updates/proapplicationsupdate200803.html
  • Simon Scionka
    January 26, 2010 at 1:01 pm
    Mike,
    Just had to say THANK YOU for this recommendation to reinstall the application update. My install disks are at my office and so when I just ran into this compressor error I was looking for a “mobile” way to fix it. This solution worked!
    Thank you,
    Simon
