Activity Forums Apple Final Cut Pro Legacy Compressor in Final Cut Pro 6
  • Compressor in Final Cut Pro 6
    Posted by Terry Tsangaris on September 2, 2009 at 3:49 am
    A discussion at work there was over whelming support for using the compressor for all work exported.
    My argument was unless exporting to specific codec’s other than the project settings there was no need to use compressor.
    When exporting media from timeline to be used for editing on another partition or Mac, is it best to use the compressor or send it as is without change.
    Many thanks
    Terry
    Doug Beal replied 17 years ago 3 Members · 2 Replies
  • Ernie Santella
    September 2, 2009 at 4:31 am
    I export right out of FCP at the timeline’s codec all the time. Especially for archiving. I also export directly for conversion. No issues here. Sure, Compressor gives you more options and I do use it for other codecs. I also use Cleaner and Episode for other codecs. All have their uses.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Doug Beal
    September 4, 2009 at 4:28 am
    I prefer to export quicktime from the timeline, current settings then generate whatever else I need from that in compressor. Compressor set up with a quick cluster can kik out multiple formats much faster than timeline exports.
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
