Activity Forums Apple Final Cut Pro Legacy Compressor Fail
  • Compressor Fail
    Posted by Brian Babarik on May 12, 2009 at 7:03 pm
    Whenever I try to export using compressor from FCP Suite 2 I receive the message: Error: A file of that name already exists. when I look at the log in the Batch Monitor there is a message saying the export failed because “Final Cut generated an error”. I’ve tried renaming projects, renaming sequences, changing the “save to” folder, kicking, screaming and praying but I still have the same issues.
    Anyone have a solution? I pay in compliments!
    Brian
    John Fishback
    replied 17 years, 4 months ago
    2 Members · 1 Reply
  • John Fishback
    May 12, 2009 at 10:33 pm
    Try exporting a self-contained or reference movie from FCP. Then, drag that into Compressor and go from there. Export Using Compressor doesn’t always work as expected.
    Also, try trashing prefs, repairing permissions and run Disk Warrior. If you don’t own it, buy it. It’s an indispensable program.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
