Activity Forums Apple Final Cut Pro Legacy Compressor Error Message on Meg2
  • Compressor Error Message on Meg2
    Posted by Brittney Cisco on April 27, 2009 at 10:02 pm
    I am trying to export a 35 minute project so that I can burn it on to a DVD. I exported my FCP Sequence using QT Movie, and then I loaded my QT movie file into the Batch Monitor. My settings are set to Best Quality 60 Minutes. It completely finishes the .AIFF as well as the Dolby file. After teasing me for 35 minutes as I watched the bar on the MPEG2 file go up to 85% complete, it finally stopped and said failed. I received an error message saying that an unexpected error occurred. (unexpected 🙁 in deed) I am thinking it is a missing MPEG2 component, but not sure how to fix this. Any ideas on how to fix this or what else it could be? Thank you
    Britt
    Rafael Amador replied 17 years, 5 months ago 2 Members · 1 Reply
  • Rafael Amador
    April 28, 2009 at 9:36 am
    Hi Britt,
    if you suspect can be an MPEG-2 component, try first re-installing the last compressor update (po Applications).
    rafael
    http://www.nagavideo.com
