Activity Forums Apple Final Cut Pro Legacy Compressor Droplets: New Folder as part of Filename Template???
  • Compressor Droplets: New Folder as part of Filename Template???
    Posted by Eddie Adams on March 25, 2012 at 9:10 pm
    What I’m trying to do is set my Compressor Droplet as such:
    Destination = Source
    Filename = /New Folder/[Source]
    The goal is to be able to drop the files, and have them re-encode and output as the EXACT filename as the original, but in a New Folder within the Source directory (I’m creating Proxy files which I will eventually replace with Originals for the online edits).
    When I try to run the droplet as stated above, I get the error: The output “MVI_2982” can not be saved in “New Folder” because you do not have appropriate access privileges. To view or change access privileges, select the item in Finder and choose File > Get Info.
    Is this even possible? I’m hoping for a completely automated droplet, where I won’t have to select the Destination each time. Any ideas? Thanks.
    Eddie Adams replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
