Activity › Forums › Apple Final Cut Pro Legacy › Compressor didn’t export entire sequence
  • Compressor didn’t export entire sequence
    Posted by Leonard Frankford on May 7, 2009 at 11:23 am
    Me again. I marked the in/out of my 1 hr 7 m sequence and exported it using the mpg2 program stream with sound. The sound came out fine this time, except the file was only 52 minutes long. There was plenty of room on my hard drive for the 2G movie. I’m starting again. Any ideas?
    Leonard Frankford replied 17 years, 4 months ago 4 Members · 4 Replies
  • John Fishback
    May 7, 2009 at 1:23 pm
    How large was the mpg2 file? What’s your system setup (computer, OS, drives and how they’re formatted, etc.)?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • John Pale
    May 7, 2009 at 1:47 pm
    Is your drive an external FireWire?
    Make sure it’s formatted Mac OS Extended, and not FAT 32, which dies not support large files.
  • Steve Eisen
    May 7, 2009 at 1:50 pm
    Leonard
    If you are in a hurry to make the DVD, export a reference movie from FCP and drag and drop it into iDVD. Oh wait, you can do that with DVDSP. DVDSP is not as hard as you think it is.
    Crack open the manual and do some exploring.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Leonard Frankford
    May 7, 2009 at 2:18 pm
    This turns out to be a stranger problem. Compressor exported the whole thing after all, which I thought it did. But I had to burn it to Toast as a data DVD, and Toast did not burn the entire mpg file (although is said it did). I’m doing it again now and I’ll see what happens.
