Activity Forums Apple Final Cut Pro Legacy Compressor Crashes
  • Compressor Crashes
    Posted by Roi Turnoy on August 22, 2011 at 11:45 am
    Hi Guys
    One of my clients has a problem with his compressor.
    He has FCP Studio 3 installed.
    Every time he drags a clip to the compressor – it crashes.
    I tried to run Compressor repair, but it didn’t help.
    Before I try to reinstall the program I would like to know if there another way to fix it.
    The clients Mac Specs:
    Mac Book Pro (1,1)
    1.83 GHz Intel Core Duo
    2GB 667MHz DDR2 SDRAM
    Mac OS X 10.6.8
    Mark Spano replied 15 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Everest Mokaeff
    August 22, 2011 at 12:02 pm
    What clip Compressor crashes on? Format? codec?
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Jason Brown
    August 22, 2011 at 1:27 pm
    Digital Rebellion makes a small app called Compressor Repair. I’ve had similar issues and it’s helped fix things up for me.
  • Roi Turnoy
    August 22, 2011 at 2:13 pm
    any kind of format – But also Quick Time reference and Self Contained…
  • Roi Turnoy
    August 22, 2011 at 2:15 pm
    As I wrote in the beginning of the post – I already tried it and it didn’t help…
  • Mark Spano
    August 22, 2011 at 4:05 pm
    every time I have any issue with Compressor, this sorts it: open Compressor, go to the Compressor menu and choose Reset Background Processing. Choose Reset and Cancel Jobs. Wait a minute. Then resubmit the job. If there’s still an error, it’s not the app, it’s the source material.
  • Roi Turnoy
    August 22, 2011 at 4:13 pm
    Hi
    It crashes from the first moment he installed the studio…
    So I don’t think reset will help (and I think I did it as well)…
    And about the source material – it crashes with different kind of clips, so it’s can’t be the source material…
    I thought it could be somthing with his mac – it’s an old macbook pro (intel version).
  • Mark Spano
    August 22, 2011 at 4:20 pm
    Then a reinstall of FCS3 is in order. Once that’s done, run Software Update and keep running it until there are no more Pro Apps updates left to install.
