Activity › Forums › Apple Final Cut Pro Legacy › Compressor Audio settings
  • Compressor Audio settings
    Posted by Frank Pledge on January 19, 2008 at 11:13 pm
    hi all,
    I have an issue with Compressor that i can’t figure out correctly. I have some DvcPro HD footage that i need to batch convert to DV. The problem is that the original HD clips have 4 track of audio and I don’t understand exactly what setting i should adjust in the audio output setting to keep the original audio exactly the same.
    i already did it wrong. It seemed to have mixed everything into a R/L stereo mix. even when I ‘un-stereo’ them in FCP the 2 channels are the same, but now split.
    In the original clips the R/L audio are seperate lavs. I need to keep it that way.
    So really my goal here is to just do a straight 4 track copy.
    G5 2.5 Dual PPC
    4Gigs Ram
    FCS2
    Leopard
    thanks SO much!
    fp
    G5 2.5 Dual PPC
    4Gigs Ram
    FCS2
    Leopard
    Frank Pledge replied 18 years, 8 months ago 1 Member · 1 Reply
  • Frank Pledge
    January 20, 2008 at 12:14 am
    Problem solved.
    “Pass through” setting in qt pulldown.
    thanks to the community regardless.
    fp
    G5 2.5 Dual PPC
    4Gigs Ram
    FCS2
    Leopard
