Activity › Forums › Apple Final Cut Pro Legacy › Compressor alternatives
Posted by Chris Stevens on September 13, 2010 at 2:22 pmNot very happy with the results from Compressor when creating an SD DVD from a 720 50p programme. Is there better software (mac) to do the job? Or should I consider a hardware solution?
Cams: Z1, EX3, HDX900.
Post :FCS6, Media 100HD V12, AE7, 12TB Sata Raid & monitoring to die for!Zane Barker replied 15 years, 12 months ago 6 Members · 10 Replies -
Stephen Smith
September 13, 2010 at 2:31 pmI’ve had great luck with Compressors SD DVD settings. You might want to look at Sorenson Squeeze or Cleaner if you are not happy.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Rafael Amador
September 13, 2010 at 2:50 pm -
Chris Stevens
September 13, 2010 at 3:33 pmVideo Format:
Video Format – PAL
Frame Rate – 25
Aspect 16:9
Dominance – Progressive
Quality:
Two pass vbr, Average bit rate – 7.7, Max bit rate – 9
Motion Est – Best
GOP:
GOP structure – IBBP closed
GOP Size – 12
Frame Controls:
Controls – On
Resize Filter – Best
Output Fields – Progressive
Deinterlace Best
Adaptive Details (Checked)
Anti Alias – 0
Details Level – 0
Rate Conversion – Fast (nearest Frame)Cams: Z1, EX3, HDX900.
Post :FCS6, Media 100HD V12, AE7, 12TB Sata Raid & monitoring to die for! -
Stephen Smith
September 13, 2010 at 3:36 pm9 is to high for a max bit rate. 9 will not play on all DVD players. Have you tried using the pre-built settings?
Stephen Smith
Chris Stevens
September 13, 2010 at 3:43 pmHave tried Apple standard settings & that looks fine on a regular TV/Panel. I’m playing out to a Pana 60″ Plasma via a quality player & it looks cleaner (less noise & more sharp) using a max bit rate of 9.
Think I can see an error in my settings – Rate Conversion is set to Fast. Should be Best me thinks?Cams: Z1, EX3, HDX900.
Walter Biscardi
September 13, 2010 at 4:04 pm[Chris Stevens] “Not very happy with the results from Compressor when creating an SD DVD from a 720 50p programme. Is there better software (mac) to do the job? Or should I consider a hardware solution?”
Telestream Episode Pro
Innobits BitVice
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
Rafael Amador
September 13, 2010 at 4:05 pmHi Chris,
Your setting looks OK (no need to set de-interlacer: Best), but I agree with Stephen about the data rate too high.
Compressor is not the best application when you have to put three hours movie in a disc, but for short programs when you can let high data rate works OK.
If you are ready to work with that data rate (reduce it a bit), make some tests with Open and Short GOPs.
rafael -
Chris Stevens
September 13, 2010 at 4:15 pmMany thanks – will try your suggestion. Chris
Michael Sacci
September 13, 2010 at 4:27 pmWhich high bitrate averages, always use CBR method, it is faster and better.
Use a 7.5 Mbps
If your footage is Progressive all the Deinterlaced settings are bypassed. (wish they would gray out).
With Compression you should be trying 20 min settings of your movie to see different results from your settings. When using CBR you can use shorter test segments. Try with frame controls off and one with down converting is a separate step before encoding to m2v.
Then if you are not getting good enough results try the other software listed. But at these high bitrates Compressor does a great job.
Zane Barker
September 13, 2010 at 5:24 pm[Chris Stevens] “I’m playing out to a Pana 60” Plasma “
ANY standard DVD is not going to look all that great on a TV that big.
If you want something that will look good on a screen that big, go with BlueRay or play it digitally using something like a Apple TV or even connecting a computer directly to the screen.
**Hindsight is always 1080p**
