Activity Forums Apple Final Cut Pro Legacy Compressor 2- “Failed: Media server application unexpectedly quit” How to fix?
  • Compressor 2- “Failed: Media server application unexpectedly quit” How to fix?
    Posted by Beelaster on January 12, 2006 at 11:34 pm
    Hello Pros-
    I have been searching the ‘net and the Cow for answers to this problem. When I attempt to export an FCP 5 timeline using Compressor 2, I get the message in the subject line. So- what is my “media server application”? Is it Batch Monitor? When I was running 4.5 etc. everything was just fine.
    If I am asking an easy question with an obvious answer, pardon me. This about hour 10 into an entire hard drive rebuild and I’m beat.
    I sure would like to depend on this app. I don’t see a reason why it wouldn’t work- right now the main harddrive is lean and mean, all repaired and such.
    Thanx for your replies, in advance,
    Bee
    PS- It doesn’t say it below, but I’m running Tiger 10.4.4. Okay.
    G5 dual 2.0/5.5gig/sonnet allegro FW800 PCI/3X250 LaCie FW800 extreme/AJA Io/Horita BSG-50/DSR-45/DSR-11/M-Audio Delta 1010LT/JVC Hi-Res Ref Monitor/stock Radeon video card/FCP Studio/Logic 7.1.1
    Beelaster replied 20 years, 7 months ago 2 Members · 3 Replies
  • Vinrose420
    January 29, 2006 at 11:02 pm
    I was having the exact same problem and came across this thread https://www.instantboard.com/users/telly/viewtopic.php?t=642&highlight=compressor
    I just tossed the .plist for Compressor in the trash, restarted my computer and it worked. Have you tried this yet?
    Susan
  • Vinrose420
    January 30, 2006 at 1:11 am
    Sorry…this is only a mediocre work around. The problem repeats when I export a new timeline from FinalCutProHD 5.0.4 to Compressor 2.0.1. This is getting old fast.
  • Beelaster
    January 30, 2006 at 4:50 am
    Is there a setting that needs to be changed? I’m amazed at the lack of info/responses about this. Either we are the only people experiencing this or the solution is so simple that nobody feels the need to embarrass us with a response.
    I really miss the old setup (FCP 4.5, etc) for ease of use, though.
    Bee
