Activity Forums Adobe InDesign Compression Transparency Problem! sos!
  • Compression Transparency Problem! sos!
    Posted by Thatfoxeleanor on May 26, 2007 at 10:37 am
    When i export from an InDesign to PDF for print, some of my shapes (solid colours) are transparent. They do not appear so in Indesign and should not when exported. I don’t know what to alter to fix this.
    Please please please suggest some options.
    -the shapes in indesign are set to normal in the transparency window in indesign
    -i think the problem is in compression?
    Thank you,
    ~ eleanor
    http://www.eleanor-rosenberg.com
    Frank Mixson replied 19 years, 3 months ago 2 Members · 1 Reply
  • Frank Mixson
    May 27, 2007 at 2:27 pm
    Have checked you transparency flattening presets? If your fills are over other fills then maybe you need to have them ‘overprint’.
    Hope that helps.
