Activity Forums Apple Final Cut Pro Legacy Compression DVpro to Mpeg2
  • Jerry Hofmann
    June 14, 2007 at 1:05 am
    Delete all of the sequence’s renders with the render manager. Then select the sequence in FCP, choose File/export/using compressor. Choose an appropriate MPEG-2 preset so that it will fit on a DVD. Most DVD Players can handle about a 7.5kbps CBR if you’re program is short enough to fit with that large a file.
    Jerry
  • Rafael Amador
    June 14, 2007 at 5:44 am
    I’ve never heard about DVPro 60. May be DVCPro50?
    Rafael
