Activity Forums Apple Final Cut Pro Legacy compression and standards conversion
  • compression and standards conversion
    Posted by Rob Dunford on March 16, 2011 at 10:39 am
    I know this is quite the right forum for Compressor, but I figured the experts here would be more able to answer the question.
    I use Compressor to convert 30 minute programmes from NTSC HD to PAL HD.
    I set the duration to 100%, but the actual PAL duration is off by 3 frames.
    I know it’s not the DF/NDF issue, it’s not a big enough error.
    So…please….what gives??
    Alexander Kallas replied 15 years, 6 months ago 3 Members · 3 Replies
  • Rafael Amador
    March 16, 2011 at 10:55 am
    Are you spotting that difference on Final Cut?
    I won’t trust QT to see that.
    rafael
    http://www.nagavideo.com
  • Rob Dunford
    March 16, 2011 at 11:00 am
    No, I am spotting this in Compressor and FCP.
  • Alexander Kallas
    March 17, 2011 at 10:33 am
    Have you missed using the frame controls tab?
    Cheers
    Alexander
