Activity Forums Apple Final Cut Pro Legacy Compression and H-264
  • Compression and H-264
    Posted by Jesse Austin on October 3, 2011 at 5:33 pm
    Hey all,
    Question, I am working with a still image (tiff images) project in FCP, using the Tiff compression setting. I have exported using both ProRes 422HQ and a uncompressed version of the edit. I need the final output to be H-264 for the web (Apples iWeb to be exact). So I bring that file into compressor and compress it down to about 15 megs. The output looks great titles, effect so forth, except it has lost a lot of the color saturation. Could some one clue me in on why this is happening and what I can do to fix this issue?
    Thanks for the help
    Jess
    Jesse Austin replied 14 years, 11 months ago 3 Members · 3 Replies
  • David Roth weiss
    October 3, 2011 at 5:39 pm
    It’s a gamma issue with h.264 compression. Adjust the gamma filter in Compressor until you get the result you’re looking for. A tiny adjustment goes a long way.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Producing Episodic TV with “24” Producer Michael Klick:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-1_Michael-Klick/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Pratul Gaikwad
    October 3, 2011 at 5:41 pm
    try exporting it thru FCP and convert it in mpegstream. In mpegstream keep bit rate max possible and get the total file in desired size.
    It just a workaround i am suggesting, generally its a bit rate which determines the pixel depth.
  • Jesse Austin
    October 6, 2011 at 12:24 am
    Thanks for all the help, got it taken care of.
    Jess
