Activity › Forums › Adobe After Effects › compression
  • compression
    Posted by Dimi Devro on December 10, 2009 at 12:05 pm
    hey, i’m a filmstudent and for school i have to make a shortfilm that lasts about 5min. I’m using after effects to make my footage somewhat cooler (lens blur, color correction,…). The problem is I want my footage to look really good (i shot it with a sony hd cam), so I make my composition’s in NTSC D1 Widescreen square pixel, no problem here, the footage looks superb, but a 10sec video is already 1.5GB, how am i suppose to get all my footage on a 4.7gb dvd? When I simply choose NTSC DV, the footage is smaller but looks really shitty. Any ideas on how to get a 5min video with good qualty on a dvd? thank you!
    Dimi Devro replied 16 years, 9 months ago 2 Members · 2 Replies
  • Brendan Coots
    December 10, 2009 at 7:08 pm
    To summarize the situation:
    – Render out your project to Animation codec (full quality, millions of colors) or similar. Yes, the file will be huge, if it were tiny the quality would suffer tremendously. Big file = higher quality (usually).
    – If the goal is to create a DVD that can be played back in DVD players, pull your huge file into your DVD authoring application and author a disc. Upon output, the DVD authoring program will automatically compress the video to fit on your DVD. The result is almost always very good, unless you tweak the authoring program’s output settings incorrectly and screw it up.
    – If you need the actual Quicktime file on a disc, rather than an authored DVD, then you will instead need to open your huge Animation codec file with a program that compresses video – Quicktime Pro is a high quality and cheap option. Output a Quicktime movie with h.264 compression set to highest quality with automatic keyframes. The resulting file will fit on a standard DVD with tons of room to spare.
    – As Dave mentioned, don’t use After Effects to output compressed video, ever. It’s just not made for that. Get used to outputting uncompressed/Animation codec videos that are huge and need further treatment for delivery to your audience. That’s the standard workflow, so best to get used to it now.
    Good Luck!
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Dimi Devro
    December 13, 2009 at 11:44 am
    thx a lot guys! that will do it!
