Activity Forums Apple Final Cut Pro Legacy compressing to QT 6.xx instead of QT 7- HELP
  • compressing to QT 6.xx instead of QT 7- HELP
    Posted by Tom Adams on May 19, 2005 at 4:46 pm
    Hello,
    I’m having major troubles having a client using a PC to view files that I’m compressing from my mac. I know it’s the age old problem…but I need a solution today!
    I can’t export (from FCP HD or QT7Pro) as QT7 and have the client dowload apple QT player because there is NO QTplayer7 for windows YET.
    I can’t compress to a WMV file becasue I’m using the popwire quicktime export plugin for mac and that loses audio sync…known problem acknowledged by their support team.
    HELP ANYONE? is there a way to have QT export to qt 6.xx?. I also have discreet cleaner 5…but that sucks and I’m not sure if it will export to QT7 or QT6.
    solution anyone??
    Tom Adams replied 21 years, 3 months ago 2 Members · 2 Replies
  • David Robinson
    May 19, 2005 at 5:10 pm
    What codec are you trying to use? As long as you compress using a codec that is available in QT 6 you should be fine. Sorenson would work.
  • Tom Adams
    May 19, 2005 at 6:24 pm
    ahahmm. I’m actually just exporting as a standard quicktime file…not using sorenson or anything. I see , so i could using mpeg 4 or sorenson or any of the other ‘codecs’ within the quicktime settings. sorry, i wish i knew more about the specifics of codecs but never have enough time to learn…to busy trying to get the jobs done…catch 22.
    any other detailed info would be greatly appreciated!
